Realtek HD - balloon says device unplugged - cutting audio constantly!
woodydean
Hi there,
Ive been getting this problem for a while now, even after system restoring.
Whenever im running something that requires audio, eg. itunes, ventrilo, youtube video etc a balloon will pop up from 'Realtek HD audio manager' saying a device (my headphones) has been unplugged, it will then say the device has been plugged in again.
It cuts the audio for about a second (very frustrating) and if i am in game, will make me lag also.
It seems to occur more frequently when i am in vent and in game, if more than 2-3 people talk at once it will happen definately.
I have tried reinstalling directX10, playing around inside the Realtek HD audio manager.. but to no prevail.
Where is the problem? What can i do to resolve this?
Thanks, anyone who bothers to read this :D
Hi Woody,
Welcome to the forum,
Check all of your plugs to make sure that they are not damaged or worn, if possible change the cables completely and try another Headset.
Try disabling all of the devices that you are not using (Realtek HD audio manager)
If you right click on one of the devices you will have the option to "show disconnected devices" make sure there is a tick in the box so that these devices will show up.
This might make it easier to troubleshoot.
You gave the example of Headphones as the device that is unplugged if this is the actual case, then start with the headset.
I hope this helps
Pooch
    Self build
    Asus M3A32-MVP Deluxe
    8 gig Samsung PC800 RAM
    NVidia 9600gt
    AD1988b
    1680 : 1050 1280 : 1024
    Enermax Chakra
    Easy Line Laser Mouse
    Standard
I have similar problem on my computer. And video freeses on every second.
Fujitsu Siemens 1519
Motherboard: Asus M2R-FVM (sound: Realtek ALC 888)
Prosessor AMD Athlon X2 64 4200+
Nvidia GeForce 8800Gt (Palit)
Vista Ultimate x64 SP1 and latest updates and latest drivers.
EDIT: I think vista updates causes these problems
FIX? Realtek HD popup - balloon says device unplugged - cutting audio constantly!
I think i have a fix and want to share :)
when u open the realtek manager,
on the top right corner it says ADVANCED SETTINGS
or in my dutch version "geavanceerde apparaatinstellingen"
right under that tekst link is a small easy to miss yellow folder icon...
when u klick that, u can NUKE the detection on your front panel..
my popups are already gone for at least 10 minutes now :)
i hope this helps anyone... let me know :cool:
Greetings
P. Thecandyjar.
(for searchers in google in the future)Realtek audio popup vista hoofdtelefoon aangesloten balloon connected disconnected plugged jack.
I also had this problem! It was very annoying, but now, thanks very much to thecandyjar :D it's working fine now, no annoying popups now. :)
Regards,
Josh!
    Intel(R) Pentium(R) D CPU 3.00GHz
    2GB RAM
    nVidia GeForce 8800GS
    Relatek HD, Creative Sound Blaster X-Fi Go! USB
    Philips 190S7FS 19" LCD Monitor
    1440 x 900 pixels
