lost sound in Media Player
t-4-2
Banned
Hello everyone,
Before I do a system restore, I wonder if someione can tell me how to get the sound back when I play the music from Windows Media Player ?
I just found out today.
Have you checked the usual culprits?
Tried a different file you know that works?
WMP Volume unmuted in the app ?
Right-click the sound icon on the taskbar and open the Volume mixer to check if anything is unmuted?
Is it just WMP sound or sounds in general?
Have you added any codec packs recently?
    i7 3770K HT ON 4.7GHz
    P8Z68 Deluxe Gen 3
    8GB G.Skill Ripjaws X 2133mhz
    X-FI Forte + ATH-AD900
    1920*1200 / 1920x1080
    Corsair AX1200W
    Lian Li PC-V1020A
Hello smarteyeball,
Thank you for your quick response.
I have found out the problem source. I just bought a electronic gadget, brand name ICON, which will record cassette music to the computer which will in turn burn it to CD if I want to. I found out that, before I can play the music recorded, I have to disconnect the ICON from the computer. I did not do that, that's why I have no sound from my WMP. There were virtually no instructions from the owner manual. Any way, thank you.
No worries, As long as you got it fixed :)
    P8Z68 Deluxe Gen 3
    Corsair AX1200W
    Lian Li PC-V1020A
Re: lost sound in Media Player vista x64
over the weekend I too lost all sound, speakers are working when I test them but I am unable to play any audio or video. I would appreciate any suggestions
