Front panel audio jacks not working
darinmoon
I have a problem similar to one posted earlier this year. I have a sound blaster live card that I took out of a dell and I've put it in an HP dc5000. Everything works except the front audio panel. I know that I need to connect them to the card but the headers don't seem to be compatible. Is there any way around this?
Assuming your Live has the connector shown here,
Connecting the SoundBlaster Audigy2 ZS to the Front Panel
the easiest would be if you still have the Dell case to pull the entire wire harness (from the front plugs to the connector) from the Dell case and swap it with the one in the HP case (if possible that is). Or you can follow that guide and make your own cable as the pinouts for that connector are the same on all Creative cards that have it. One other option is to buy one ready made (pretty sure I have seen them cheaper on ebay),
The X-Tap -- Sound Blaster Audigy/X-Fi Harness
    Me
    Athlon x2 7750 BE
    Asus M4A78 Pro
    2x2gb Kingston
    Sapphire HD 4830
    X-Fi Xtreme Music
    Acer P221w and Acer 1916w
    1680x1050 and 1440x900
    Antec Earthwatts 500W
    Antec Sonata III
    Logitech G5 v2
    Logitech Wave
