Problems with Fatality Sound Card
Rekt
Hi everyone
I had upgraded to a new FSC only a week ago and set it up on XP64 and it was working fine.
A week later I decided to finnaly change to vista.
But from the fresh install the first sound that ever came out of the card is a constant sorta 'beeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeep'
at a low level
no matter what drivers or programs I install it does nothing to resolve the problem.
I tried disablying the the device but it stopped for only a second and then carried on making the noise!!!!!
Some one help im at my wits end.
Im using ati 4870 graphics card, 2.4 intel quad, P5W DH deluxe motherboard with 600w PSU Cooler master
Your sound card sounds faulty. Have you tried uninstalling (remove the card) and then trying again?
    Acer Aspire 5920gmi notebook
    NVIDIA GeForce 8600M GS
    Realtek
    crawl
yeh I tried that just now and its still not fixed the problem. It cant be faulty cause it was working with my XP set up just fine!!!!
AGHHHHHHHHHHHHHHHHHHHH!!!
    Realtek
    crawl
Sorry I cannot be of more assistance, but I suggest you test it somewhere or somehow (your card). Other than that I have run our of suggestion as to what to do.
:o
    Realtek
    crawl
