Realtek HD Audio Manager in Vista 64
Homer
I am trying to adjust my mixer to accomodate my new speakers, the voice is too low, and the base is too high. I have accessed the mixer and tried to make it tollerable, but have failed. There is no direct bass and treble adjustment, and there is not a "user" or "custom" setting. There are only presets, the problems with these presets, is that they work in certain situations, but not in others. Any advise? Am I looking in the worng place? Can I put software in place to adjust the levels indepent of each other?
I am using the onboard sound card on an Abit IP35 Pro, and I am using Home Premium 64. Any advise would be greatly appreciated.
Hi Homer and welcome to Vista Forums :party:
Sorry, but at the moment there are only preset options in the equalizer for the Realtek HD Audio Manager. There is a possibility that this feature might be introduced in a subsequent driver, but I wouldn't hold your breath. All I can suggest is that you keep an eye on the download site just in case a newer driver has this feature.
    Dwarf Dwf/11/2012 r09/2013
    ASRock Z77 Extreme4-M
    ViewSonic VA1912w Widescreen
    Gigabyte IF233
It sounds like my options are limited to a new sound card, my question is whether I would be using my sound card software for this feature, or if Vista would limit me to the presets even with a new sound card?
Thanks for the quick reply btw!
Hi Homer,
Do your speakers have bass and treble controls as well as volume? However, if you are referring to the volume level then this can be adjusted individually. Right click the speaker icon in the system tray and select 'Playback Devices'. Click on 'Speakers' and then 'Properties'. Select the 'Levels' tab and scroll down the list.
The individual volume levels can be adjusted here.
    Gigabyte IF233
Unortunately, the only adjustment on the speakers are the volume and the bass. I just bought some Logitech x-240's. Great entry level speakers, but the voices are off in games. Music sounds good because I can adjust it depending on what program I have plaing the music, but in game, I am not able to distinguish between the bass and treble levels...
Hi ALL!
This forum look's like very great for Vista problems to solve :)
About the levels I get only Speakers LEVEL to change no center sub or my back speakers but they all do work and I did try already the new drivers from realtek.
Any idea?
    ME
    C2Q6600 [email protected] GHz Scythe Infinity
    DFI X38-T2R
    2x2GB OCZ@960 c4
    EVGA 8800Ultra on 27" Dell
    Auzentech X-Fi Prelude @ Logitech Z-5500
    Dell 27"
    1920x1200
    WDC SE16 640GB,WDC 250GB,WDC 2x500GB
    PSU TT Toughpower 1.2KW
    TT Shark
    ALL AIR
    Razer Copperhead on eXactMat
    Razer Tarantula
    4Mbit down and 512kbit upload
