Realtek HD Audio Codecs
Burnboy
I just installed ultimate 64 and I cannot get my sound to work. I have an asus m2a-vm motherboard with onboard audio. At first in the sound mixer it only showed spdif audio which i do not have. Sound came out as static, a high pitched digitized static if that makes sense. I have tried several codecs and nothing. any suggestions?
Hi Burnboy,
Try installing these drivers;
Realtek
I hope this works
Pooch
    Self build
    Asus M3A32-MVP Deluxe
    8 gig Samsung PC800 RAM
    NVidia 9600gt
    AD1988b
    1680 : 1050 1280 : 1024
    Enermax Chakra
    Easy Line Laser Mouse
    Standard
If this is not the answer go to Control Panel, Hardware and sound, sound and make sure that loudspeaker is the default device you may have to disable the digital device
this is done by right click and using the context menu
Pooch
    Self build
    NVidia 9600gt
    AD1988b
    Enermax Chakra
    Standard
that link just leads to datasheets but I have tried to codecs from realtek several times as well. If it helps the static is in sync with when sound should be coming out. it gets louder and quieter as a normal sound should
Hi Burnboy,
Follow the link on the right hand side of the window under quick links is a link to the audio driver.
This is the driver I use it works very well under x64
Did you read my second post?
    Self build
    NVidia 9600gt
    AD1988b
    Enermax Chakra
    Standard
Pooch
See the picture, my set up is partly in german but the icons are still the same
    Self build
    NVidia 9600gt
    AD1988b
    Enermax Chakra
    Standard
    Self build
    NVidia 9600gt
    AD1988b
    Enermax Chakra
    Standard
when i download the zip file there are folders in it for 32 bit 64 bit and vista. the setup exe under 64 bit says it wont run with vista when i click on it but the exe in the vista folder installs fine but i still have the same problem
I have just downloaded and tried these drivers, as with you only the driver in the Vista folder has installed, but it works fine by me.
I can configure my sound system everyway possible but in the worst case I just don't get sound. I cannot replicate this screaching.
Do you uninstall the old drivers before installing the new one? if not try it.
Are you sure that your loudspeakers work and that they are connected
properly? can you try them on a different system?
    Self build
    NVidia 9600gt
    AD1988b
    Enermax Chakra
    Standard
Just as an after thougt do you have a michrophone connected?
If yes try disconnecting it
    Self build
    NVidia 9600gt
    AD1988b
    Enermax Chakra
    Standard
no mic. one anomaly i am noticing is that realtek digital output keeps popping up. I do not have a digital card. I keep disabling it and it keeps coming back no matter what i do.
You said in your graphic card post that every thing is now working, was that also for the sound problems??
    Self build
    NVidia 9600gt
    AD1988b
    Enermax Chakra
    Standard
