audio dosen't works..sound "buzz...buzz.." came out when start pc
awieweng
i need a help..
i am a new user vista ultimate x64..
my problem is when i turn on my pc, my audio dosen't works properly and it sound likes "buzz..buzz.." when windows start,play movies or everthing that need sound.:sick:
i am using asus M2A-VM motherboard..
i already install the latest update of my motherboard driver..but i still got this problem..:confused:
can anyone help me???:cry:
thanks...i appreciate for any suggestions.. :geek:
    AMD 64 X2
    asus M2A-VM
    CORSAIR XMS2 TWIN2X (2GBX2) CL5 800MHZ 6400DHX RAM
    NVIDIA 9600GT X2
    DELL P1130 22"
    1600X1200
    160GB HITACHI 640GB WDC
    1Mbps
Hello awieweng, and welcome to the Vista Forums :party:
As a work around you may want to try this ...
Control Panel - Hardware and Sound select the default output device (speakers) and properties - on the enhancements tab there should be an option to "disable all sound effects" select this and OK out of the dialogue. you may need to re-boot but see if your sound is now better.
if it is then you have a known issue with WMP and certain set-ups MS is aware of the problem and are "working on it" so hopefully it will be fixed soon
    2 x 1920x1080 @50Hz
    Asus M5A78L-M USB3
    32GB [4x8GB] DDR3 1600 MHz
    Samsung 32" TV
    68 MB Down 18.5 MB Up
