Any help with this greatly appreciated.
I recently started to use the monitor speakers - previously had the monitor volume turned right down.
There is an annoying medium-high pitched hum thru. the speakers.
The volume of the hum varies with the volume on the monitor, not the volume settings on Vista.
Detaching the 3.5mm sound lead ( DVI lead attached )reduces the hum considerably.
Detaching the DVI lead (sound lead attached ) removes the hum.
Using VGA lead makes no difference.
Have tried different sound drivers, different video drivers, reinstalled the o/s - makes no difference.
As the hum seems to be travelling down the DVI/VGA lead,
tried a different graphics card ( with passive heatsink - no fan ) - makes no difference.
Took the side off the pc and can just discern the same hum if I get my ear in the right place - from inside the pc.
Detached the rear fan - no difference.
Detached the mobo fan - no difference.
The only thing left is the psu - could the fan noise/vibration be traveling via the graphics card to the monitor ?
If so, any ideas how to stop it ?
Thanks
SIW2
Thanks
SIW2
- Operating System
- Vista
- Intel E8400
- ASRock1333-GLAN R2.0
- 4gb DDR2 800
- nvidia 9500GT 1gb
- Operating System
- win7/vista
- intel i5-8400
- gigabyte b365m ds3h
- ballistix 2x8gb 3200
