ululator
I recently purchased a Dell desktop with 64-bit Vista Premium. Audacity 1.2.6 would not record: I got a message telling me to "check the input device settings and the project sample rate."
I checked in Audacity>Edit>Preferences, & there were no Recording Device options listed at all.
After Googling all possible avenues for advice, I found an extremely simple solution… that actually works!
* Select Personalization from the Control Panel.
* Select Sounds
* Select the Recording tab.
* In my case, there were 3 options shown: Front Mic, Microphone, & Line In, all grayed out & showing as not plugged in.
* Right click on any one of them choose "show disabled devices."
* This brought up the Stereo Mix option.
* Select Stereo Mix, Choose Properties, and click Enable.
* Voila! Now it worked the same way as Wave Out Mix in Windows XP, & I could record streaming audio with no problems!
Hope this helps!
* Select Sounds
Hope this helps!
