Hi All,
I have an Hewlett Packard SR5401UK pc running Vista 32-bit it has onboard graphics & sound but I've just installed an NVIDIA 8800gs graphics card, the card works fine but for some reason the sound has disappeared!! i've just updated the realtek drivers but still have the problem!! it worked fine before installing the g.card , whats even more strange is that when i plug in my headphones i can hear sound but nothing at all through the speakers!!
When i installed the 8800gs it disabled the onboard g.card automatically itself i was wondering if it has done the same with the sound? but if it had i wouldnt be able to hear sound through the headphones right? device manager says the sound is working fine!!
im totally baffled by this if anyone could give me some advice id be grateful!! Thanks for taking time to read this!!
Regards,
Gaz
Regards,
Gaz
