SB Audigy 2Zs No System Sound, No Audio Card Sound
zqueve01
About a month ago I ugraded to the latest drivers for SB audigy 2ZS and everything ran smoothly until now. I can't understand all of a suden have no sound at all. Checked everything is connected properly. Please help. I tried google to find and answer but not luck.
No need for help. I connected an old set of speakers to my audio card and it works fine; therefore, it only leads me to conclude that the speakers on the moniter itself are defective. I've had the monitor for 2 years and a half and it's under warrantee for 3 years. I have already contacted viewsonic regarding the issue. I should be able to get the product serviced with no problems.
Glad you got a resolution to your problem. Thanks for the feedback.
    Scratch Built
    Intel Quad Core 6600
    Asus P5B
    4096 MB Xtreme-Dark 800mhz
    Samsung 206BW
    1680 X 1024
    550 w
    Thermaltake
    Targus
    Microsoft
    1500kbs
    Self built.
