Sound from PC heard on SKYPE phone only.
punkin
New PC, new user of Vista...Intermittent sound from PC speaker & SKYPE phone; now only phone....Not even close, as a techie...
'Device Mgr's:...Realtek High Def. Audio & Philips VOIP080..
I noticed this a.m., Philips VOIP080 has taken over...Necessary to have two Mgr's?
I'm not sure what other info you need..
Thank you
Punkin
    Dell/INSPIRON 518
    3.00 GB
    Realtek High Definition Audio & Philips VOIP080
Go into control panel then sound and see if both are listed if they are select realtek and set that as default.
    HP Compaq Presario/SR5113WM
    AMD Athlon 64 X2 3600+ 1.9Ghz
    Asus M2N68-LA
    PNY Nvidia 8400 GS 256MB
    On board RealTek
    Acer X163W LCD
    1366x768
    Dynex 400w
    Nothin Special
    Stock
    Wireless Logitech LX7
    Comcrap 10mb cable
Thanks mansrm81...I selected Realtek but cannot set as default...It(device driver) is listed as "unknown application".....Lost sound from Skype phone now..
    Dell/INSPIRON 518
    3.00 GB
Solution found.. I spent 5hrs with a microsoft techie yesterday only to discover there is no solution and that that fact is on the SKYPE site...Amazing that!
    Dell/INSPIRON 518
    3.00 GB
BTW, mansrm81 as the 'Vista Pro' certainly must know that..
    Dell/INSPIRON 518
    3.00 GB
