Tron Thomas
I am running the 32-bit version of Windows Vista Enterprise on a Hewlett Packard workstation xw 8000.
I installed a SoundBlaster Audigy audio card in the system.
The system indicates the sofware driver is install an functioning properly.
From the Control Panel I can go to Hardware and Sound, click on Sound, select Speakers, select Configure, and then click on the Test button that appears in the Speaker Setup dialog. I will heard sound through the headphones connect to the sound card.
However, when I try to play any sound on the system, like clicking on the slider for the volume control in the Task Bar, I do not hear any audio through the headphones.
What can I try that will allow me to hear sounds through the headphones attached to the system?
