Mustangsupra
Whenever i turn the computer on after it has been asleep the sound will not play. It will not play in WMP 11 or in itunes 8. It also says that the test for the sound cant play. Then when you go into the sound control panel it says no audio devices are installed. I have installed the newest driver I could find and it still does it. The thing is, if I restart (the computer) the sound works fine. Or if i install the driver it works fine until the computer goes to sleep.
I have vista Home Premium x64 (service pack 1), AMD Phenom Quad, Nvidia 9800GT video card, Asus M2N-SLI 560 Nforce motherboard, 4 gigs of ram, and the built in sound card is a c-media cm6501. If you need to know more let me know.
thanks
jeremy
thanks
jeremy
- AMD Phenom 9850 Quad-Core (2.5GHz)
- Asus AM2, nFORCE 560 M2N-SLI
- 3838MB RAM DDR2 800
- EVGA GeForce 9800GT
- Built in C-Media CM6501
- Dell SP2208WFP
- 1680x1050
- 500GB SATA-II 3.0Gb/s 7200RPM HDD
- PSU
- 600w
- Case
- Raidmax Sagitta II
