Can no longer disable soundcard without restart?
smarteyeball
Eye know, eye know
For some strange reason, I can no longer disable my soundcard in device manager without having to restart the computer. It will disable if I end the audiodg.exe process, but since restarting audiodg.exe and re-enabling the soundcard dosen't return my sound, I have to restart anyway.
Any ideas?
    i7 3770K HT ON 4.7GHz
    P8Z68 Deluxe Gen 3
    8GB G.Skill Ripjaws X 2133mhz
    X-FI Forte + ATH-AD900
    1920*1200 / 1920x1080
    Corsair AX1200W
    Lian Li PC-V1020A
Just out of curiosity why do you want to disable your soundcard for.
    HP Compaq Presario/SR5113WM
    AMD Athlon 64 X2 3600+ 1.9Ghz
    Asus M2N68-LA
    PNY Nvidia 8400 GS 256MB
    On board RealTek
    Acer X163W LCD
    1366x768
    Dynex 400w
    Nothin Special
    Stock
    Wireless Logitech LX7
    Comcrap 10mb cable
I disable the soundcard when I want to use my 360. The PC is connected to my amp via coax and the 360 via optical. Unfortunately both are the same 'channel' and it's either one or the other and pulling the coax cord out every time is not the best solution.
My PC virtually runs 24/7 and disabling the soundcard was the easiest way to free up the amps 'channel'.
    P8Z68 Deluxe Gen 3
    Corsair AX1200W
    Lian Li PC-V1020A
Unfortunately, you don't state where you're from. If you are from the UK, then perhaps this is the sort of thing that you are looking for: Digital Optical & Coaxial Audio Switch Box > Maplin (unfortunately, they don't deliver outside the UK). Failing that, what make and model of amplifier do you use? If your amplifier has more than one optical input, then this might help: RadioShack.com - Cables, Parts & Connectors: Connectors & connectivity: A/V connectors & adapters: Cables To Go Coax-Optical Digital Audio Converter
    Dwarf Dwf/11/2012 r09/2013
    ASRock Z77 Extreme4-M
    ViewSonic VA1912w Widescreen
    Gigabyte IF233
Thanks Dwarf, unfortunately I'm in Australia so the Maplin switcher is out, but the idea does give me something to work on. (I'm bound to add more devices down the track). My amp/receiver is a Sony DAV-DZ850KW which for digital has only has one coax and one optical input.
I'm not sure if this makes a difference, but I installed the ASIO4all drivers awhile ago in conjunction with Adobe Audition 2 for music recording. Normally I would have uninstalled them straight away to to test if that's whats causing my issue, but I had A LOT of hassles just getting Audition to record in the first place and I'm a little reluctant to mess with that at the moment. As I'm typing I have a sinking feeling that's what I may have to do.... I'm still open to other suggestions however :)
    P8Z68 Deluxe Gen 3
    Corsair AX1200W
    Lian Li PC-V1020A
    Gigabyte IF233
That switcher looks like just what I need.
Thanks again Dwarf. Your effort is much appreciated. Consider your scales tipped :)
    P8Z68 Deluxe Gen 3
    Corsair AX1200W
    Lian Li PC-V1020A
