Rundll32.exe error = No Sound!
wapwap
Hi there, I've just returned to these forums after a long spell away following a total system failure requiring reformatting. I got so sick of my pc I stopped using it for a few months. Now I've reformatted (AGAIN!) and I'm starting to have problems again...
I have no sound and when I click on the Sound icon in the Control Panel I get a rundll32.exe error message.
Code:
[INDENT]Problem signature:
  Problem Event Name:    APPCRASH
  Application Name:    rundll32.exe
  Application Version:    6.0.6000.16386
  Application Timestamp:    4549bb52
  Fault Module Name:    mmsys.cpl
  Fault Module Version:    6.0.6000.16386
  Fault Module Timestamp:    4549d2a3
  Exception Code:    c0000005
  Exception Offset:    0000000000005371
  OS Version:    6.0.6000.2.0.0.768.3
  Locale ID:    2057
  Additional Information 1:    e094
  Additional Information 2:    07a0e9595b24741d2d20ba6b23d695c9
  Additional Information 3:    6dc9
  Additional Information 4:    b9430fc1bfd395cd40720d6c0f75b33e
[/INDENT]
I've been to the Asus website and downloaded and installed the latest audio driver (CM6501) for my mobo but all that's done is change the type of device installed to C-Media from PnP in the device manager. The C-Media sound config says there's no device installed.
If it's relevant I also cannot open the User Accounts settings under Control Panel or open Display Settings. I also have an account missing from my logon screen.
Can anyone help please? Many thanks!
    AMD Athlon 64x2 Dual Core 6000+
    Asus M2N-E SLI nForce PCI-e
    4GB Kingston DDRII
    512MB Nvidia GeForce 8600 GT
    Acer 22" Widescreen TFT
    320GB Hitachi SATAII
    Other Drives: TSSTcorp CDDVDRW SH-S202N ATA (Lightscribe) Router: TP-Link TL-WR641G Super G 108Mbps
I had previously tried disabling my sound device and rebooting but that didn't work. I just tried to uninstall my sound device but now my device manager won't open!
I get the following message in the device manager window:
MMC Could not create the snap in. The snap in might not have been installed correctly.
CLSID: {74246BFC-4C96-11D0-ABEF-0020AF6B0B7A}
    4GB Kingston DDRII
    Vista
    Intel E8400
    ASRock1333-GLAN R2.0
    4gb DDR2 800
    nvidia 9500GT 1gb
    win7/vista
    intel i5-8400
    gigabyte b365m ds3h
    ballistix 2x8gb 3200
Thanks for the advice, I'll try a repair install and if that doesn't help I'll reformat....again!
**UPDATE**
Help!!! I did a repair install but now for some reason my copy of Vista isn't authenticating as genuine when it is! I waited till my pc booted after the repair install before putting my key in but now I have a message in the bottom right of my screen saying THIS COPY OF WINDOWS IS NOT GENUINE!
The problem I had with sound is fixed, but it seems kind of irrelevant now compared to a genuine copy of Vista losing authenticity for some reason.
**2ND UPDATE**
Did a phone activation then rebooted. The "...not genuine" message has gone from my desktop. Appears to be fine now.
Thank you for all your help! :D
    4GB Kingston DDRII
