Solved (Kinda?) IDT HD Sound on Dell Studio 17 - headphone port
I have a Dell Studio 17 that I am experiencing a sound problem with - I have NEVER been able to get sound out of the internal speakers, except with the Dell Diagnostics application CD that I downloaded and burned.
I've gone as far as upgrading to the latest drivers, to tinkering with the driver, to reapplying the latest BIOS update to actually re-imaging the machine back to the Dell default image.
I spent over 2 hours on the phone with their tech support guy and he has been unable to get it working. He doesn't seem to want to listen to me though when I tell him that it appears the sensor in the jack is bad..
How do I know this? This is what my IDT Control Panel applet looks like with the Dell included drivers with nothing but the power plugged into the laptop.
Notice the Right Side Panel - the far left jack, which is synonymous with the far front jack on the right side, thinks there is something plugged into it.
If I plug in headphones into that front jack, it works fine. If I plug in external speakers into the same jack, it works fine.
When I plug into the middle jack, the 2nd port gets larger and "bolded" - when I unplug it, it goes back to normal size. When I hover the cursor over that far left jack, it says that headphones are plugged in.
Upgrading to the newest drivers adds the HDMI port to the "Jacks" section on the right.
Now tech support wants to call me tomorrow and spend lord knows how long hand re-installing Vista Ultimate from the ground up - not from the Dell image. Gee - nothing like wasting what little time I have at home with my family glued to the laptop with tech support doing something that I know won't do squat for me.
I'm sorry - but - there is a SERIOUS problem if the Dell restore image doesn't fix the problem - this is not a settings issue - this is a HARDWARE issue!
I'm at the point where I am willing to just bypass the ports on the side of the machine in favor of using the internal speakers if I can find a way to do it.
Is anyone aware of a way to tweak the system into ignoring the external audio jack and go right to the system speakers?
- AMD Athlon 64x2 3800+ (Socket 939)
- MSI K8N SLI
- 2GB Corsair DDR in dual channel mode
- 2x BFG Geforce 7600GT in SLI mode
- Soundblaster Audigy 2
- Big ol' 21 inch Gateway LCD monitor
- 1680x1050
- 160GB SATA1 (Western Digital) 500GB USB External (Western Digital)
- PSU
- 600 Watt BFG
- Logitech G7
- Logitech G15
