You should upgrade or use an
alternative browser .
sound keeps stuttering towards the end of each track
when using media player the sound keeps stuttering towards the end of each track.
can anybody help? i have no idea why this keeps happening.
i have the same problem.
help!
Staff member
HI guys, and welcome to the vista forums,
Try this,
right click on the sound icon in the tray,
select playback devices,
select your active playback device (the one with the tick),
select enhancements
and tick the box to disable all sound effects
ok the boxes till back to desktop
run Media player and see if it is improved if not then disable the enhancements in WMP (equaliser SBS etc),
if this corrects the problem I would then go to your Laptop/Motherboard/sound card manufacturers site and check for the latest drivers
unfortunately this bug is known to the manufacturers and to Microsoft but apart from this workaround is yet to be solved
Operating System
2 x 1920x1080 @50Hz
Asus M5A78L-M USB3
32GB [4x8GB] DDR3 1600 MHz
Samsung 32" TV
Internal
Crucial CT256MX100SSD1 256GB SSD,
Seagate ST2000DM001-1CH1 2TB,
External (USB3)
Seagate Backup+ Hub BK SCSI Disk 8TB
2.5/3.5 Hot Swap Cradle, USB3 + eSata (client HDDs)
NAS 4TB
68 MB Down 18.5 MB Up
i think that did it!
thanks sooo much!
btw it wasnt a problem in media center, just in media player
Staff member
I know it's a strange one I have a desktop and a laptop with exactly the same sound chip and driver and only get the problem on the laptop even running through the same speakers
Operating System
2 x 1920x1080 @50Hz
Asus M5A78L-M USB3
Samsung 32" TV
Internal
External (USB3)
NAS 4TB
