Solved lost volume bar
All of a sudden I went to up the volume with the up volume button and the volume bar is gone. The sound increases but to what level I don't know visually. I tried updating driver and that came back with best driver is all ready installed. I have no clue how to get it back.
    Self built
    AMD Athlon 64x2 6000+ 3.0ghz
    Asus M4N78 Pro
    3Gb PC2-5300 DDR2 @ 667mhz
    VIA HD Audio
    OEM HP
    OEM HP
I had a online chat session with HP. I had to go to programs, pc help and tools, recovery manager, advance option, hardware driver reinstallation and then pick my keyboard app. and click reinstall, then reboot and all is back to normal. Pass this along for all other HP systems users.
    Self built
    Asus M4N78 Pro
    VIA HD Audio
    OEM HP
    OEM HP
Thank you for posting back the solution you found and results.
