Dolby Control Center
tangster03
Hello everyone,
I would like to ask if anyone knows where I can get Dolby Control Center for Vista x64. I am using Intel DP35PD Media Series mother board. Thanks.
    Intel Q6600 Core 2 Quad @ 2.4 Ghz
    Intel DP35DP Media Series
    SimpleTech 4GB DDR2 PC-6400 Dual Channel Mode
    XFX GeForce 8800GT Alpha Dog Edition
    Creative Sound Blaster X-Fi Xtreme Gamer Pro Fatal1ty Series
    Samsung SyncMaster 226BW 22-inch LCD
    1,680 by 1,050 pixels
    Western Digital 500GB 7200 RPM Western Digital 80GB 7200 RPM
    Apex Power Supply 500-watts
    Mercury
    Intel
    Genius
    Genius
    DSL 512 kbps
    -Creative T7900 7.1 Speaker System -Logitech Dual Action Gamepad
    Core 2 Duo E6600
    Intel 975XBX2
    8GB's of DDR2 800
    Radeon 3870X2
    HT Omega Claro
    Viewsonic VG2030wm Widescreen LCD
    1680X1050
    120GB 200GB 320GB
    ThermalTake Toughpower 700
    Antec P182
    four 120mm fans
    Microsoft Wireless Intellimous Explorer 2.0
    Microsoft Natural Multimedia Keyboard
    10MB
    16X LG DVDROM & LG Dual Layer DVD Burner Logitech X-540 speakers
    Mercury
    Intel
    Genius
    Genius
    DSL 512 kbps
You're welcome. I would use the onboard sound on my D975XBX2, but I have a soundcard that still works good.
    Core 2 Duo E6600
    Intel 975XBX2
    8GB's of DDR2 800
    Radeon 3870X2
    HT Omega Claro
    1680X1050
    120GB 200GB 320GB
    Antec P182
    four 120mm fans
    10MB
The Dolby Control Center is included in the latest audio drivers for the DP35DP motherboard.
Intel® Desktop Board DP35DP Audio: IDT* 92XX Driver
Hello WildEagle,
I just installed the sound driver you referred me. There is no Dolby Control Center included. And I cannot use 7.1 of my Creative T7900 speaker system. Only the 2 front speakers and the subwoofer are working. How can I make my 7.1 speaker system work? Thanks a lot.
    Mercury
    Intel
    Genius
    Genius
    DSL 512 kbps
The Dolby Control Option is there, it's in one of the last options in the IDT control app.
As for setting 7.1 sound, open up The Control Panel, then double click the icon that is labeled Sound. Then highlight the listing for the onboard sound and select configure. This will enable you to set Vista to 7.1 sound.
Another option for configuring Dolby Surround with the onboard sound, is to highlight the speaker option, associated with the onboard sound and select properties. On one of the tabs you will find options for configuring Dolby Surround sound. There isn't much on the IDT control panel for configuring Dolby Surround Surround, as once it is enabled on the IDT control panel, you can't configure Dolby Surround from the IDT control panel.
    Core 2 Duo E6600
    Intel 975XBX2
    8GB's of DDR2 800
    Radeon 3870X2
    HT Omega Claro
    1680X1050
    120GB 200GB 320GB
    Antec P182
    four 120mm fans
    10MB
Hi WildEagle,
I already did the configuration in the properties of my onboard sound. The test of 7.1 speaker setup is okay, the only problem is the side speakers are not producing sound during the test. The 2 front speakers, the center speaker, the 2 rear speakers, and the subwoofer produced sounds. But when I play my media player, only the 2 front speaker and the subwoofer produced the sounds.
And about the Dolby Control Center, I didn't find in the IDT Control Panel. Friend, if it's okay with you can you send me snapshots how to find those things because I might missed some steps. Thanks a lot WildEagle.
    Mercury
    Intel
    Genius
    Genius
    DSL 512 kbps
He won't send them - but he can post them here.
The forums are for public knowledge - asking for private helps robs the forums of their purpose.
    The Beast Model V (homebrew)
    Realtek HD Audio (onboard)
    2 * 1920 x 1080
    Logitech MX Master (shared)
    Logitech G15 (gen 2)
    Lenovo ThinkPad E545
    AMD A6-5350M APU
    Lenovo
    Conextant 20671 SmartAudio HD
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
Hello johngalt,
I was talking about posting the snapshots here in my thread. I wasn't asking for private messages.
    Mercury
    Intel
    Genius
    Genius
    DSL 512 kbps
You're gonna have to forgive me, I've been using my HT Omega soundcard, but I have been trying to find some screenshots of the onboard sound control panel on the net.
I figured on keeping my onboard sound, as a backup in case my soundcard croaks.
    Core 2 Duo E6600
    Intel 975XBX2
    8GB's of DDR2 800
    Radeon 3870X2
    HT Omega Claro
    1680X1050
    120GB 200GB 320GB
    Antec P182
    four 120mm fans
    10MB
Hello johngalt,
OK, but you used the word *send* - in a forum you don't send stuff in the open, you send it via PM, and you post in open forums.
    2 * 1920 x 1080
    AMD A6-5350M APU
    Lenovo
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
I realize this is a little late in time for posting but after doing a search I found this info and also have the program "Dolby Control Center (DCC)" that came with my Gigabyte GA-EX58-UD4P Motherboard using the I7 Intel 920 with VistaX64. The audio from the onboard is working just fine as I get DTS and Dolby Digital, getting the correct drivers for that was not fun. I am using realtek HD audio driver 6.0.1.5772 to make it all work. I have this DCC and want to see how much better, if at all the DCC will improve the sound. Don't get me wrong, it sounds great and all but if I can improve it with what I have already then why not use it. My problem is I can't find if the "Dolby Control Center" program works in X64. When I tried loading it in my XP machine it stated that the program was a Vista only program. I figure if it is Vista x32 only then it would not allow me to use the install for x64. I checked Gigabytes site and there is no mention of it. I am quite sure if it does work I simply need the correct driver. Does anyone know of one or if it does work in Vista x64 bit? After reading this post I feel that is is compatable but I can only get it working if I can find the correct driver. I did not think creating a new thread was practicle as some of this thread does apply to my situation.
Thanks
    Home made
    Intel i7 920 Broomfield-Not overclocked
    Gigabyte X58-UD4P
    12 Gig Corsair Dominator Triple Channel 1600 DDR3
    Sapphire 3870 X2 - Just the one now
    Creative Blaster X-FI Titanium Optical to Yamaha Receiver
    Panasonic 50 inch Plasma via HDMI and used as just a Monitor
    1920x1080
    Sata Seagate 750 Gig 32MB for the Vista 64 bit and second drive is Sata 300 Gig for extra storage.
    Cooler Master 1000
    Antec 900 extra fans
    Cooler Master Hyper-N520
    MX 5000 Logitech
    MX 5000 Logitech
    Cable 12MBPS
    LG GGW-H20 Blue Ray writer running with Cyberlink Ultra 9. Home Theater system through Yamaha 7.1 Receiver connected to 11 Def Tech speakers, including powered Def Tech 15 inch sub. What can I say I like movies! Not much of a gamer.
Well, Gigabyte just let me know that the Dolby Control Center is not Vista x64 ready, only for Vista 32. Thread closed again.
    Home made
    Gigabyte X58-UD4P
    1920x1080
    Cooler Master 1000
    MX 5000 Logitech
    MX 5000 Logitech
    Cable 12MBPS
