Headset and install problem
DeSade
Can someone please tell me how to get around this problem.
Its a USB headset, there is no driver software.
Are you running as a standard user? Is UAC enabled or disabled? Have you taken ownership of any files or folders? Have you tweaked your system by disabling / setting to manual start any services?
    The Beast Model V (homebrew)
    Realtek HD Audio (onboard)
    2 * 1920 x 1080
    Logitech MX Master (shared)
    Logitech G15 (gen 2)
    Lenovo ThinkPad E545
    AMD A6-5350M APU
    Lenovo
    Conextant 20671 SmartAudio HD
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
UAC is disabled
I took ownership of wdf01000.sys to fix another issue
I have not disabled any services.
Try running the following form CMD prompt to let it fix your system files
Code:
SFC /SCANNOW
Actually, first and foremost I'd return ownership of that file to whatever it was before - that is a hidden and critical system file that should *not* be messed with.
    2 * 1920 x 1080
    AMD A6-5350M APU
    Lenovo
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
Code:
SFC /SCANNOW
I do not know how to return it.
I did not take it on a whim, it was advice from the Logitech techs.
See if the SFC will return it for you (I think it will).
    2 * 1920 x 1080
    AMD A6-5350M APU
    Lenovo
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
It didn't fix it.
Gave me the message that some corrupted files were found it it was unable to fix them.
Can you tell me how to return ownership please
Honestly, if it fond files that it cannot fix, and you looked at the CBS log, it sounds like you installation has become corrupted and will need a complete format and reinstall. However, since most of your system is working OK, I'd go ahead and start backing up files and settings (make sure you realize that settings and files are located in different areas - so backing up, say, just the green special folders in you user folder is not going to get all your settings - you'll need to either show all hidden files and folders to see the AppData folder(s) and back them up, or at the very least make a manual copy of the folder and subfolders to another place that will not be affected by the format.
I personally have a dual HD setup where all my special folders (green ones) are located on a separate physical drive - making formatting and reinstalling that much easier.
    2 * 1920 x 1080
    AMD A6-5350M APU
    Lenovo
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
Thats terrible news :(
I did not install the system this time around as I couldn't figure out the grub to get a dual boot and except for this one thing the system is running so very sweetly.
I would simply replace the headset (as I want to do anyway) but now I am not sure it will help.
I am searching for that file to see if I even have it.
    2 * 1920 x 1080
    AMD A6-5350M APU
    Lenovo
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
Ok I returned ownership of that wdf01000.sys file to TrustedInstaller and SFC /Scannow is running without any errors.
Yet I still cannot install this headset, the screenshots still apply as its still the same messages I am getting.
    Me
    Athlon x2 7750 BE
    Asus M4A78 Pro
    2x2gb Kingston
    Sapphire HD 4830
    X-Fi Xtreme Music
    Acer P221w and Acer 1916w
    1680x1050 and 1440x900
    Antec Earthwatts 500W
    Antec Sonata III
    Logitech G5 v2
    Logitech Wave
Mak its plugged into the motherboard so I am sure its powered.
Stormy, its the 3rd one on your list
Ok I was just gonna say sometimes the USB1 USB2 ports on the motherboard for the case in front/side dont always give enough power and weird things can happen~
