My computers integrated sound card have worked with no problems for 7 months. Now i try to connect sony Hi fi center witch is also working perfectly, the problem is that jack sensing on the back panel is no longer working, only two ports of 6 pop up and gives me to choose what i have connected (but gives no sound), others dont react no mater what i plug in: microfone, headphones, other line out cables.
I have tried to reinstall the drivers, enable disable all of the audio devices, The strangest thing is that front panel is working perfectly.
gigabyte GA-MA-790fx-DQ6 with integrated 8-ch ALC889A High Definition audio
8GB ram, 9600, 3870, raid 0, 850w, Vista64 sp1
- Phenom 9600
- Gigabyte GA-MA790FX-DQ6
- 4x2Gb 800 Patriot signature line
- Sapphire 3870
- 2x500GB Samsung in raid 0
