SB Audigy 2 ZS and Vista Home Premium 64bit
Raptor22
Hello folks...
I recently installed a fresh copy of Vista 64bit Home Premium on my HDD, and I am unable to get the sound to work for my Audigy 2 ZS PCI card. Non of the outputs work from the rear panel of the card (both headphones and speakers), and the system says that it has the proper drivers installed (SBAXVSD_PCDRV_LB_2_12_0002.exe). Any help is useful, thanks in advance!
Raptor22
    AMD 64 X2 4600+
    MSI K9N4 SLI
    4GB OCZ Reaper HPC PC6400
    MSI NX8800GT 512M
    Maxtor 160GB 7200RPM SATA
The drivers you have installed were the first release Vista drivers and are garbage, if anything you want to use the latest drivers that were released last month (which are working just fine opn my Audigy 4). Alternatively you can also give the daniel_k driver set a try,
SBAX_PCDVT_LB_2_15_0004EQ.rar - FileFront.com
which will also allow you to use some of the apps as well.
    Me
    Athlon x2 7750 BE
    Asus M4A78 Pro
    2x2gb Kingston
    Sapphire HD 4830
    X-Fi Xtreme Music
    Acer P221w and Acer 1916w
    1680x1050 and 1440x900
    Antec Earthwatts 500W
    Antec Sonata III
    Logitech G5 v2
    Logitech Wave
