5.1/7.1 recommendations??
fieseler
ive been using my inspire 5100 5.1 surround for about 7 years & want to replace them. I had a glance at gigaworks g500 & decided against them coz i dont want to skyrocket my electricity bill.
I was thinking of going for Creative Inspire 7.1 T7900 but at the moment im not sure i have enough room for 2 other speakers. If i bought these & decided not to plug the side speakers in would it work as 5.1?
    §ĮŁΣNŦ Д$$Д$$ĮN
    Xeon X3360
    P5W64 WS Pro
    EVGA Geforce GTX470 SC+
    Samsung T200
    WD 1TB RE3
    Thermaltake Toughower 750w
    NZXT Lexa Silver
    Zalman CNPS10x Extreme
    Razer Deathadder 3500dpi
    Razer Lycosa Mirror
    24Mb/s
Hi fieseler,
Yes, that should be possible. You should be able to configure the audio output so that it can operate in 2 channel mode for stereo speaker output, 4 channel mode for 4 speaker output, 6 channel mode for 5.1 speaker output and 8 channel mode for 7.1 speaker output. Note that it will only work correctly in a specific mode if you set it to that mode.
Dwarf
    Dwarf Dwf/11/2012 r09/2013
    ASRock Z77 Extreme4-M
    ViewSonic VA1912w Widescreen
    Gigabyte IF233
sweet. Solved a lot of problems. Cheers Dwarf!
    §ĮŁΣNŦ Д$$Д$$ĮN
    Xeon X3360
    P5W64 WS Pro
    Samsung T200
    WD 1TB RE3
    NZXT Lexa Silver
    Razer Lycosa Mirror
    24Mb/s
Another set of 5.1 speakers to take a look at are the Logitech X-540 speakers. I bought a set over a month ago, and like them much better than my old Altec Lansing 5.1 set, which I gave to a friend.
    Core 2 Duo E6600
    Intel 975XBX2
    8GB's of DDR2 800
    Radeon 3870X2
    HT Omega Claro
    Viewsonic VG2030wm Widescreen LCD
    1680X1050
    120GB 200GB 320GB
    ThermalTake Toughpower 700
    Antec P182
    four 120mm fans
    Microsoft Wireless Intellimous Explorer 2.0
    Microsoft Natural Multimedia Keyboard
    10MB
    16X LG DVDROM & LG Dual Layer DVD Burner Logitech X-540 speakers
