My computer was working with no problems at all until I decided to download the latest versions of Itunes(7.6.2)/Quicktime(7.5) for some music shopping.
At first, everything was still working as usual and I could play my purchased and downloaded music with itunes,winamp and the media player with no issues whatsoever.At the end of my session, I switched off my PC.
The next day, however, my sound had completely vanished from my system.I don't get any system sounds,music,streaming audio... nothing at all.After I browsed a multitude of forums, both Apple and Vista, I still could not figure out what my issue was, as I had no hardware issues up to the itunes/quicktime installation.
Nothing is muted.
Speakers worked fine before the reboot.
My Soundblaster X-Fi ExtremeMusic has all the necessary drivers installed and is being recognised fine.
My onboard audio is disabled through BIOS.
All my codecs and players were working fine until I rebooted, after installing itunes/quicktime.I was using a multitude of players without issues. (Zoom Player,CoreMediaPlayer,Winamp,VLC all worked fine).
I used system restore twice, without success.
I tried uninstalling/reinstalling codecs and players, without success.
Uninstalling itunes/quicktime didn't help.
I'm at my wits' end. The problem clearly lies with the itunes/quicktime installation and something it did with my sound output or registry. I think I'm not the only one with this problem, but none of the suggested workarounds/fixes worked for me.
I hope someone who had a similar issue can help me fix this, because I really don't want to format and reinstall everything from scratch.
Thanks in advance.
Nothing is muted.
Thanks in advance.
