Realtek HD Drivers Problem - Jack Sensing
kirol
Hi!
I have: AsRock Alive NF7G FullHD mothermoard with integrated:
- 5.1 CH Windows® Vista™ Premium Level HD Audio (Realtek ALC662 Audio Codec)
- Chipset embedded HDMI Audio
And i have't sound.
I read this forum, but a have't so options, what you wrote:
[URL="http://images.netbag.hu/20080702/19293320150.jpg"][/URL]
[URL="http://images.netbag.hu/20080702/19293638266.jpg"][/URL]
[URL="http://images.netbag.hu/20080702/19294050732.jpg"][/URL]
Than you see it I have't Connector Settings.
How can I turn off "Jack Sensin".
Please help me! (Sorry for my english.)
Re: New Realtek HD audio driver update
Try uninstalling the drivers, rebooting, and then installing again.
    The Beast Model V (homebrew)
    Realtek HD Audio (onboard)
    2 * 1920 x 1080
    Logitech MX Master (shared)
    Logitech G15 (gen 2)
    Lenovo ThinkPad E545
    AMD A6-5350M APU
    Lenovo
    Conextant 20671 SmartAudio HD
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
This is a driver - you need to make sure it is recognizing your RealTek driver and hardware.
What does device manager say?
    2 * 1920 x 1080
    AMD A6-5350M APU
    Lenovo
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
I Uninstalled the driver, issues it with a sick-note on his end, that restarts, at this time if I do not restart, there is a sound!
I don't understand that - but if you uninstalled, then the picture is not valid anymore, right?
Also, I had another reply in here saying that your version is the same as mine, but it was lost somewhere...
anyway, if you reboot what happens?
    2 * 1920 x 1080
    AMD A6-5350M APU
    Lenovo
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
I'm sorry for it, I see it now, I don't use the front panel.
My problem is a following:
I use this PC to watch 720p movies on Samsung LE37 A431T2.
The soundcard gives a sound on the cable, but I insert it vainly into TV, there is not a sound on it.
Only (have sound) then I uninstalled the driver, and on the end i don't restart it.
Vista installs the sound card automatically if I restart it, and I haven't got again sound.
OK, so when you uninstall the driver, then there is Sound going out to the TV - but after drivers are installed, then there is no sound.
Do this - Get Guru3D - Driver Sweeper (Setup) download from Guru3D.com and install it - reboot into safe mode - run it - remove all traces of RealTek - reboot - let Vista load the default drivers - see if sound works. If not install the latest 1.97 drivers - see if sound works.
If not, then open the sound control panel and click the lowercase letter i in the bottom right corner and make screen shot of that.
    2 * 1920 x 1080
    AMD A6-5350M APU
    Lenovo
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
OK, thanks, I try it immediately. BUT!
I say it, if I bind earphones onto him, there is a sound always then, there is not a sound bound onto TV only, only then, when the driver uninstalled, and while I do not restart it.
DVI-HDMI, but may be not too Realtek causes the mistake.
I installed Windows XP, (integrated audio DISABLE) and I inserted Sound Blaster Live 5.1 Digital.
Was a sound, I believed it will be everything perfect finally, and I say it does not interest me an integral sound card.
Then I installed only possibly nForce chipset driver, and at this time already here it on XP with Sound Blaster Live 5.1 Digitall neither was a sound.
Possibly it nForce driver does the mistake.
I may install Windows up now again, and I am listening very much already now when the sound disappears.
Were you audible already from one like this?
For the benefit of other users, please post your solution (and I bet it has to do partially with the fact that you're using a DVI to HDMI converter but not setting your TV to manually get the sound from another source instead of HDMI, which includes audio)....
    2 * 1920 x 1080
    AMD A6-5350M APU
    Lenovo
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
It was a sound always, only on TV not. I use DVI-HDMI cable for the TV's and the PC'S binding.
I wanted the sound to RCA cable carry it over on.
In this manner the TV on HDMI2 RCA waited for the sign.
The essence: Chipset embedded HDMI audiowhich supports HDMI signal through DVI-D port by using DVI to HDMI adapter.
Since it is the cable in RCA was made to join, in this manner on the HDMI did not catch the sign.
The TV was not because of this sound.
Solution:
- I don't need RCA cable, olny DVI-HDMI cable.
- In BIOS must enable DVI-HDMI audio
- And in the Windows must HDMI DIGITAL output use!
For Windows isn't this the default output but normal digital output.
I don't understand it, if in BIOS I disabled the HDMI-DVI audio why wasn't on then RCA sound, but with the above method whatever perfect.
I did not write the solution down because I am not too good from English.
I hope for it you understand the essence because of that. :)
No worries - if anyone needs a translation I will help them.
In the meantime, the reason, I suspect, that it would not transfer sound to the TV because the TV sensed an HDMI input - and tried to get audio from HDMI only. You need to configure TV to not use HDMI Audio and use RCA audio instead.
    2 * 1920 x 1080
    AMD A6-5350M APU
    Lenovo
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
A solution is a yes, it.
But I don't know it momentarily how is needed.
But that essence that in this manner good, and with at least a cable less. :)
Other cable is needed in that manner there if I bind it onto 5.1 system.
This is good for me now in this manner.
