PLZ HELP ME FIND: External USB Voice Modem Compatible with Vista
UAV-PHD
Hi All,
I was wondering if anyone could help me find an external (USB) voice modem that would be compatible with Vista. There should be mic in, spkr out jacks on the modem for it to be a true voice modem.
I would like to use my computer as a telephone. I want to be able to plug the telephone landline into the external modem, and use programs (such as MS Outlook) to make telephone calls from my computer.
Can anyone provide insight?
Thank you!!!
    The Beast Model V (homebrew)
    Realtek HD Audio (onboard)
    2 * 1920 x 1080
    Logitech MX Master (shared)
    Logitech G15 (gen 2)
    Lenovo ThinkPad E545
    AMD A6-5350M APU
    Lenovo
    Conextant 20671 SmartAudio HD
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
johngalt,
I appreciate your time in that. But unfortunately, I've looked at all of these, and none of them are exactly what I'm looking for. I've actually even bought that Hiro modem. None of them have mic in, spkr out ports.
Some modems will claim to be "voice modems" that will relay voice through the sound card of the computer, but this creates garbled sounds as well as seconds of delay.
- UAV-PHD
Understandable - I am not sure if you're going to find such a rascal, but I'd check out 3COM - I have always been their biggest fan when it comes to modems (well, their US Robotics line anyway, since they bought the company) as well as their NICs....
Also, have you read around about IRQs and how forcing hardware to use different IRQs may change the way they perform? ISTR that with Voice modems you *really* had to play around with some of the internal hardware settings to make a Voice modem transmit voice over the telco lines when the sound was being passed to it from the computer sound card - but I don't remember if it was the modem itself that needed to be played with (in terms of settings, such as device settings and / or modem initialization strings) or if it was the sound card that needed adjusting...
    2 * 1920 x 1080
    AMD A6-5350M APU
    Lenovo
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
Thanks. I having been searching for that for longer than I care to admit and stumbled across it here.
  • Memory
    ATO Radeon HD 3200
    640 GB
