Sound card: X-Fi Xtremegamer - Well a while back I did not want to go to Vista, but decided to try it out. Liked it for how it worked, except I had a lot of problems with my sound card. At random times, I can't say what caused it because I'm not sure if it was anything I did, my speakers would make this loud irritating noise like something was ripping(kind of like a ton of paper for about 2 seconds) and then just die. The only way I got sound back was to restart my computer. I got fed up with this so I reformatted back to XP Pro. In XP I had absolutely no problems.
So I upgraded my computer a bit and had to get a new hard-drive, so I decided, you know what? I'll put Vista back on as a x64 this time. Same thing in it's own sense. Right now the only time is has definitely happened was when I was playing a game, but I think it's the sound card because right when a friend talked on Ventrilo, my system froze on me and the only way to get out, restart manually. I JUST tried to download the latest driver to see if it works so it's installing as I type this message. So hopefully it will help. Last time though, it did not.
First Computer
AMD Athlon 64+ X2 5400+ 2.8GHz
Radeon x1650 GTX 512MB
4GB Ram
250GB HD IDE
Current Computer
Intel Core 2 Quad 2.4 GHz
nVidia 8800 GTX 756MB
4GB Ram
250GB HD Sata
Any help is greatly appriciated. Thanks.
First Computer
4GB Ram
250GB HD IDE
Current Computer
4GB Ram
250GB HD Sata
