Hello
First off, I apologize if this isn't considered to be in the correct forum or not. I wasn't too sure, because I'm not exactly sure what the problem is.
My internal microphone currently is not working. I receive sound perfectly fine from everything, but my internal microphone will not record it. I have spoken into it, created loud noises, and have done whatever else I can, and it still does not pick anything up. My settings are enabled, yes. I've been to onto the HP site and have gone through step-by-step instructions over various solutions that could fix this, but none of it seemed to have worked.
I've tried a numerous amount of times to use the sound recorder and play it back, and when I do the sound does not show up.
Has anyone had this problem before? If so, how did they fix it? Or does anyone know maybe what it could be and any other possible solutions available?
Some information that might possibly be able to help (I'm not sure if it will or not, but it can't hurt.):
I have:
a Compaq Presario F730US Notebook PC
Vista Home Premium
the product number is: GR967UA#ABA
and the serial number is: CNF7480N4C
the sound device I have is: Conexant High Definition Audio
I have:
Vista Home Premium
