Sound stopped working after downloading driver
MrJester69
I downloaded a webcam driver and now my sound won't work. It says it's running and music is running, even the speaker's sound test will work, but nothing comes out except during the speaker test. I went to my sound options and the "realtek digital output" bar is moving and all, but that sound test won't work.
I also deleted the driver and restarted the computer. Still no sound. Help :(
Oh, also, there's no start up sound like there used to be either and I'm sure everything is still plugged in properly. It only stopped after I used to webcam on msn after downloading the driver. I think the computer thinks there is a mic on or something. I've tried adjusting all the settings and disabling it. Still nothing.
Ummmmmmm you deleted the drivers? WHich drivers? The sound (realtek) drivers or the webcam drivers? I lack the knowledge to help you but that is important info for those who can.
    Intel Core2Quad Q9450
    nForce 790i Ultra SLI(evga)
    8 GB DDR3 1333MHz
    2 e-GeForce 9800GX2(SLI mode)
    WD1500AHFD (Raptor 150 GB 10,000 RPM)
