wapwap
I was hoping SP1 would solve a lot of issues I've been having (see related link below)
http://www.vistax64.com/media-center/137811-wmc-wmp11-keep-crashing.html
Now it seems a new (possibly related?) issue has surfaced. Since installing SP1 I have no sound at all.
In device manager under sound there is a PnP audio device listed but this is wrong, it should be the onboard audio (I believe it used to say CMedia...something). It has an exclamation mark and won't update the driver.
I have found MANY copies of the same solution on the net (uninstall device, scan for hardware changes, reinstall driver) Fix for Sound Missing or No Sound after Vista SP1 install | Windows Reference
BUT....it won't install the driver. I tried downloading the driver from my mobo manufacturer's site but I keep getting a failed install.
Can anyone help please? I really, really don't want to have to format again. Thank you
- AMD Athlon 64x2 Dual Core 6000+
- Asus M2N-E SLI nForce PCI-e
- 4GB Kingston DDRII
- 512MB Nvidia GeForce 8600 GT
- Acer 22" Widescreen TFT
- 320GB Hitachi SATAII
- Other Info
- Other Drives: TSSTcorp CDDVDRW SH-S202N ATA (Lightscribe) Router: TP-Link TL-WR641G Super G 108Mbps
