Quick Vista x64 Realtek HD sound question
turner56
New Vista user here. I've recently upgraded my pc to Vista x64 and have a question regarding my new Realtek HD sound chip, ALC889A. When in games, should I set audio to hardware or software processing? Also, should I always disable EAX? I'm assuming I have to enable DTS Connect for 5.1 in games and programs.
Thanks!
Providing that you have no problems with the audio when playing games, I would leave it to use hardware processing with EAX enabled. Only change the settings if a particular game doesn't work correctly.
    Dwarf Dwf/11/2012 r09/2013
    ASRock Z77 Extreme4-M
    ViewSonic VA1912w Widescreen
    Gigabyte IF233
