New vista X-Fi audio driver from creative
panais
Power User
Creative has now release a new driver for Creative Sound Blaster® X-Fi™ series of audio devices.Filename: SBXF_PCDRV_LB_2_15_0006.exe
The new driver fix many bugs and compatibilitys errors with windows vista.
For more details, read the rest here >--->
</Title> <meta name="CREAF.dateCreated" content="22/03/2008 00:22:29" /> <meta name="CREAF.renderNode" content="193.95.171.120" /> <meta name="CREAF.clientNode" content="74.53.55.52" /> <meta name="CREAF.lcsSetting" content="1_357_61" /> <meta name="
    Custom Built by me.
    Intel Core 2 Quad Q6600
    Gigabyte GA-X38-DS4
    KINGSTON HYPERX DDR2 4GB (2X2GB) PC6400 800MHZ DUAL CHANNEL KIT
    SAPPHIRE RADEON HD4890 OC 1GB GDDR5
    2/4/5.1/7.1-channel Realtek High Definition
    Samsung LE40A656F1 1080p 100Hz LCD HD TV 50,000:1
    1366x768 in Desktop,1920x1080p in gaming and video
    C:\WD VelociRaptor 150 GB,10,000 RPM D:\WESTERN DIGITAL WD15EADS 1.5TB CAVIAR GREEN SATA2 E:\WESTERN DIGITAL WD15EADS 1.5TB CAVIAR GREEN SATA2 No Raid.Copy Paste Is The Safest Way.
    Seasonic 700W 80plus
    A-Case Twin Engine BB
    3 thermaltake smart case fan II + 1 arctic cooling fan
    Wirelles Logitech Laser Mouse MX620
    Wireless Logitech LX710
    ADSL 4000plus
    F:\Sony high speed sata Dvd Rewriter KINGSTON HYPER X FAN +Cordless Rumblepad 2
For sound blaster support, here's their website:
Creative Labs : Customer Support - Drivers & more for all your Creative products
    Intel Q6600 Quad Core 2.4 Ghz
    Dell 0TP406
    Nvidia 8800 GT 512 MB
    Dual Dell 22" Widescreen
    3360x1050
    320 GB Internal Main 500 GB USB External 160 GB USB External 2TB USB External
    DSL 3MB
My new mobo X38-DS4 cannot detect my Sound Blaster X-Fi XtremeGamer Fatal1ty Pro.
Any idea,solution?
Thanks
    Custom Built by me.
    Gigabyte GA-X38-DS4
    ADSL 4000plus
That's kind of odd. Did it detect before the driver update?
Also, have you tried putting it in another PCI slot? Did you check BIOS and make sure there's nothing that would keep that from working?
I update bios and its look ok
    Custom Built by me.
    Gigabyte GA-X38-DS4
    ADSL 4000plus
Btw Sound Blaster X-Fi XtremeGamer Fatal1ty Pro is not fully compatible with vista 32\64bit
    Custom Built by me.
    Gigabyte GA-X38-DS4
    ADSL 4000plus
Any ideas why i randomly get a hissing in my left ear almost like static noise and then to make it go away i have to play music really loud and it almost pops back to normal.
This happened before and after the driver install and only happened with vista, its not headphones as ive tried 3 different ones. Very strange and somewhat annoying.
It happens maybe once a day.
I'm having major problems with my X-Fi Platinum. Resulting in BSOD's and systems restores(thank god for that)!! Now I have gotten so far as to getting the old(none working) driver off and installed the new driver... BUT... no sound and a yellow exclamation point in my device manager.
Any ideas as how to get it to work fully?
    C2Q 6600 G0
    ASUS Extreme Striker 680i
    CELLSHOCK 4x1GB PC2-6400CL4
    2 x ASUS 8800GT SLI
    2 x Raptor 37GB RAID 0
You probably need to reinstall the driver if it's got a yellow exlamation mark by it. You could try to double-click the faulty item in your device manager and then choose "update driver" or whatever it's called. Either that or get the full download from the Creative website and simply install from there.
Tryed it... and it didn't work ... thanks anyway
    C2Q 6600 G0
    2 x ASUS 8800GT SLI
