ikjadoon
Hi, I have Vista Ultimate 64-bit, along with a Dell SP2008WFP monitor, which comes included with a webcam and an array microphone, both connected via single USB cable.
I can record my voice using the Sound Recorder with the array microphone and there is movement of the mini-equalizer in the Sound Dialog-Recording Tab under the USB Microphone, so it is functional. Maybe a bit too sensitive, but it works.
Now, when I go to set up Speech Recognition and recite the sentence, the bar moves very erratically, not at all in cue with my voice. I have a 3.5mm microphone in which it works perfectly, though.
Does Speech Recognition not work with USB Microphones? Is it too sensitive? Is it picking up echoes? I've tried turning off the speakers to no avail.
If anyone has any help, that would be greatly appreciated.
Thanks!
~Ibrahim~
P.S. Great forums, btw.
Thanks!
~Ibrahim~
- Overdrive PC
- E6600 @ 3.5GHz
- P5N-E SLI
- 4GB DDR2
- 8800GTS 640MB
- Onboard Realtek ALC883
- Dell SP2008WFP
- 1680x1050
- WD 640GB (50GB OS/100GB Programs/490GB TV Recordings) Seagate 320GB
- PSU
- Enermax 620W
- Case
- Cooler Master Stacker 830
- Cooling
- 6x120mm
- Razer Copperhead
- Gateway OEM
- 6Mbps/512kbps
