Advice for a sound card
colt1911
FreeBird
I just purchased a set of Logitech Z5500 speakers and would like to now add a sound card to my system. I see that there have been some issues with certain card drivers and Vista 64 bit . Is there a card that you could recommend that works with Vista 64? I will be gaming , watching movies and listening to music as well. Thanks for your advice and help.
    Q9450
    P5K Premium
    Corsair PC6400 DDR2
    Evga 8800 GTS 512
    Pri. - Seagate 500 32 mb Sec. WD 500 16mb and wd 250 16 mb
I've had good luck with my Creative XtremeGamer. Other people will tell you Creative products are terrible. I believe that there is a thread called "Best Soundcard for Vista x64". Take a look there.
