This is a Vista issue because the unit works fine on an XP machine.
Vista seem to recognize it and install the drivers when it's plugged in, including the message that the device has installed successfully.
The only thing I can think of is that the drivers are bad. I've remove the device from device manager and nothing seems to help.
Any ideas?
Any ideas?
