Problem in mp3 files details
naruto88
Hi everybody,
I have a problem in my laptop vista ultimate 46 bit
the problem is I cant change any details of all mp3 files such as the name of artist, album, genre and the title on the mp3 file itself .
I tried lots of solutions such as download k-lite mega codec and divx and the problem still. Also on the details pane on the bottom of each folder
I am waiting for your solution cause I had this problem before twice and I formated the laptop but this time I want a real solution
WAITING FOR YOU........
    Dual Core E7200
    Asus P5K
    4GB DDR2 800 SDRAM
    GForce 8600GTS 512mb
    Auzentech XFi Prelude 7.1 on Onkyo605 Rxer
    20" Samsung SyncMaster 206BW
    Sky UK
Hi. That program will change ANY aspects of the mp3, including all the changes you listed. I would suggest reading the help file/manual. This program can be complex in some areas, so please read. I use this all the time to change exactly what You want changing.
Hope that clear it up a little for you.:)
    Dual Core E7200
    Asus P5K
    4GB DDR2 800 SDRAM
    Sky UK
Thanks my friend but your program works very will but what I meant the main problem still in the windows I cant change the details from the windows itself
So what you actually want to do is change the filename of the mp3? You CAN do that in TagandRename. Browse the file you want, right click and choose Edit File/Folder name. This will then show up in Windows as your renamed mp3.
If this is not what you meant, then apologies, but this is what I can gather from what you wrote. To rename the file in Windows, just right click and select Rename...is that what you mean?
    Dual Core E7200
    Asus P5K
    4GB DDR2 800 SDRAM
    Sky UK
Sorry my friend If I interrupted you
you can see my problems in the attachment
note for the picture
When I tried to change the album name to drive and click on save then that annoying error message appears.
Well, to be honest, I really dont know how to resolve that, sorry.
If anyone else can have a go, please try.
    Dual Core E7200
    Asus P5K
    4GB DDR2 800 SDRAM
    Sky UK
I have the same problem. Could you solve the problem? If yes, how?
    Intel E6400
    Gigabyte 965P-DS3
    Crucial Ballistix Tracer PC2 6400 2x2GB
    HIS HD3870
    Seagate 7200.11 500GB SATA2 NCQ x 2
I think that Windows Media Player automatically names everything. If you disconnect from the Internet it should change but when you re connect it will probably change back. I think its like track ID and scans it and names it whatever song it is.
    Hewlett Packard
    3.40Ghz / 2.20Gz Duo Core
    2GB / 3GB
    160 GB / 160 GB
Windows Media Player (or, WiMP, as I call it) has an option to automatically connect to the Internet to update your music files . Turn that off and see if it helps.
    The Beast Model V (homebrew)
    Realtek HD Audio (onboard)
    2 * 1920 x 1080
    Logitech MX Master (shared)
    Logitech G15 (gen 2)
    Lenovo ThinkPad E545
    AMD A6-5350M APU
    Lenovo
    Conextant 20671 SmartAudio HD
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
Because my wmpalyer is not working, I cannot turn that option off. Is there any other way to do this?:confused:
    Intel E6400
    Gigabyte 965P-DS3
    HIS HD3870
you cannot run WiMP at all?
    2 * 1920 x 1080
    AMD A6-5350M APU
    Lenovo
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
With my account it is not possible to run. I click the wmpaler icon but nothing happens. However, If I logon via another account, no problem occurs. I think some registry problems occured in my account. Because accidentally I used CClaener :(
    Intel E6400
    Gigabyte 965P-DS3
    HIS HD3870
Make a new profile and copy all your files over to the new profile - it would probably be easier than trying to fix at this point, especially as it runs fine on other profiles.
    2 * 1920 x 1080
    AMD A6-5350M APU
    Lenovo
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
Yesterday, I checked wmplayer x64. It is working:) So now instead of wmplayer x86, I started to use wmplayer x64.
    Intel E6400
    Gigabyte 965P-DS3
    HIS HD3870
