no sound in vista ultimate (x64)
t3m0
Performance Lover
i have hooked up my pc 2 my panasonic hdtv and am now using it as my current monitor. however, there is no sound whatsoever. no matter what i do, i dont get any sound at all. I connected video through a hdmi to dvi cable and audio through a 3.5m jack (male to male) please help! thanks for your time
  • Monitor(s) Displays
    61" Panasonic 1080 HDTV
    500w
    First Build
and yes, I have installed codecs and the tv sound works, but it doesnt work through my cp
    500w
    First Build
does the sound work if you hook up normal pc speakers/headphones to the audio jack?
    Intel Quad Core 2.66Ghz
    Dell
    3GB
    NVIDIA 8800GT
    2qty 500GB SATA 7200RPM RAID Performance Stripe
i found a solution, using cp speakers only, no solution to use my tv speakers yet.i fixed it by downloading the latest realtek codec and enabling bass boost on my pc.
    500w
    First Build
