Solved Cleaning Fan
XGenius
Power User
Um, I have a computer around five years old and I want to clean the fan since it's getting a little loud and hotter. Any help? (It's a laptop)
    HP Compaq Presario C700
    Intel Pentium Dual Core T2370
    HP 30D9
    2GB 677Mhz
    Mobile Intel 965 Express Chipset Family
    Conexant High Definition SmartAudio 221
    WDC WD1200BEVS-60UST0
Laptops are tricky so I would see your user's manual. There might be a way to have it clean itself. You could try spraying a can of compressed air into the exhaust. Otherwise you'll have to take it apart. I'm not very good with that.
    Windows 8.1 Industry Pro x64
    HP Pavillion Elite HPE-250f
    8 gb
    ATI Radeon HD 5770 1 gb ram
    Alienware 25 AW2521HF
    1920x1080 &1680x1050
    1 TB x2
    Dell Poweredge T140
    8GB 2666MT/s DDR4 ECC UDIMM
    1 TB & 360 GB x2
I'll research!
    HP 30D9
    2GB 677Mhz
Good idea. You just might find a maintenance manual for your laptop. :eek:
    8 gb
    1 TB x2
    Dell Poweredge T140
    1 TB & 360 GB x2
    I5 3570K
    Gigabyte Z77-DS3H
    Gigabyte Geforce GTX 660 TI
    creative x-fi
    Both 1680 x 1050
    Technika TKOPTM2
    Logik
Youtube also has great videos.
    Dual L5639 // i7 950 @ 4.0Ghz
    gtx 560 ti // gtx 260-216
    Dual 22" // Headless
I used the manual that I found on the hp website and managed to take out the keyboard and clean the fan a little bit. To access the fan completely will require me to take apart almost everything. Can't someone create a maintenance-friendly laptop case? Adding a vent that is attached only by screws right below the fan wouldn't be too hard, right?
    HP 30D9
    2GB 677Mhz
Yha I hear yha.... My Acer is actually lie that with a huge door with access to the fan and heatsinks.
Lucky you! :)
    HP 30D9
    2GB 677Mhz
I believe that there are some that actually use the fan to push the dust out. But generally laptops are hard to work with.
    8 gb
    1 TB x2
    Dell Poweredge T140
    1 TB & 360 GB x2
I agree with townsbg, every time I have worked on a laptop that requires taking apart it has been a pain, laptops are optimised to keep things small and allow heat dissipation.
    I5 3570K
    Gigabyte Z77-DS3H
    creative x-fi
    Both 1680 x 1050
    Technika TKOPTM2
    Logik
Interesting, didn't know about that.
    HP 30D9
    2GB 677Mhz
I bought my laptop with Vista Home Premium on it, $1700 AUD but tbh if/when it starts acting up, I'm not even going to bother trying to fix it.
To me laptops are a disposable item,(getting cheaper daily) now my desktop on the other hand, if a component breaks/dies I will spend the money on it too get it back. :party:
    Homebuilt
    AMD Phenom II x 4 965
    Gigabyte GA-MA770T-UD3P
    4GB DDR3
    Nvidia GeForce GTX 750 TI
    Creative Sound Blaster X-Fi Xtreme Audio
    Phillips 19"
    1280 x 1024
    1 x 128GB Samsung 840 Pro SSD 1 x 1TB Sata 1 x 160GB IDE 1 x 2Tb WD External My Book Elite 1 x 1TB WD External My Book Elite 1 x 4TB WD External My Book
    Thermaltake 850W XT
    Coolermaster Storm Sniper Black Edition
    AC-ALPINE-64PRO ARTIC COOLING
    Microflacid Sterile
    12 year old Compaq, cant see any of the letters anymore :)
    ADSL2+
    My husband and I divorced over religious differences.. He thought he was God and I didn't.
If I ever upgrade, I'm going to build myself a computer. Well, after a lot more researching.
    HP 30D9
    2GB 677Mhz
Are you saying that you consider 1700 to be "disposable"?:confused:
    8 gb
    1 TB x2
    Dell Poweredge T140
    1 TB & 360 GB x2
The undamaged parts still have value. CPU's could be worth like 500.
    HP 30D9
    2GB 677Mhz
Doubt $500 I bought an intel x9100 used o ebay for $150 from a retailer.
The Intel i7 cores are worth that much, some of them.
    HP 30D9
    2GB 677Mhz
Okay, How bout I bout 2 xeon L5639s on ebay for $320 each to go in my SR-2.
Used cpu's more than a generation old are rather cheap.
i7 2630QM | eBay
