Solved 7770 GHz edition overclock help
nostaw5
"POW" Ur dead
Power User
Hey all :3 long time.
Cutting to the chase:
I purchased a HIS HD 7770 GHz edition upgrading from my S***ty last generation HD 6450.
Core speed is default at 1000MHz Mem is default at 1125Mhz.
If I increase sliders even a little bit (in AMD Overdrive (which has safe limits)) I get the error: Your Display Driver has stopped responding and recovered. This is when I'm not even gaming, just with a window open. Temps are fine at 26c...
Your thoughts?
    Custom Gaming Rig 780G
    AMG Athlon II X2 255 3.8/2MB/2500MHz 45nm AM3
    Gigabyte GA-MA78LMT-S2 AM3, Core Boost, Ultra Durable 3
    2X 4GB Kingston DDR3 1066MHz @ 1666MHz Dual Channel
    HIS HD Radeon 7770 GHz Edition iCooler Core: 1000MHz
    Realtek HD Audio
    Dell E2311H DVI/VGA 5ms response, Full HD
    1920x1080 @ 60Hz
    320GB Seagate Barracuda 7200.02 SATA II
    Cooler Master Extreme Power Plus 700w
    Lian-Li PC-6010 With Side Window
    Aywun A4 80mm fan
    Logitech K120 Wired Mouse
    Logitech K120 Wired Keyboard
    802.11B/G/N 17Mb/s
    AMD Catalyst 12.6 Thomson A/B/G/N Router LiteON CD/DVD Player GAME PERFORMANCE: Battlefield 3: 41 FPS High 1x AA @ 1280x720 Mass Effect 2 and 3: 60 FPS Highest 4x AA @ 1920x1080 Counter Strike Source (and other Valve games): 300 FPS (max FPS in game) Highest settings 8x AA 16x AF @ 1920x1080!!!
I'm thinking that it's sat its maxed overclock with stock voltages.
Which is sorta what i'd hope to see, as paying for an overclock that wasn't maxed would make me sad.
    Dual L5639 // i7 950 @ 4.0Ghz
    gtx 560 ti // gtx 260-216
    Dual 22" // Headless
Yeah but people who have reviewed the exact same card can raise core and mem speeds
    Realtek HD Audio
    1920x1080 @ 60Hz
    Aywun A4 80mm fan
    802.11B/G/N 17Mb/s
oh and on stock speeds it gives me the error if i use Sony Vegas Pro 11... WFT AMD!!! I thinks I might return the card and get a faster 560 TI
    Realtek HD Audio
    1920x1080 @ 60Hz
    Aywun A4 80mm fan
    802.11B/G/N 17Mb/s
That sdounds like a bad card then. there should never be an error at stock settings.
I got a 560ti and loike it...
first i raised the voltage and power settings, looks like stable stock speeds
illl run furmark and see what happens.
    Realtek HD Audio
    1920x1080 @ 60Hz
    Aywun A4 80mm fan
    802.11B/G/N 17Mb/s
Downgraded to 12.4 drivers all good now :D
    Realtek HD Audio
    1920x1080 @ 60Hz
    Aywun A4 80mm fan
    802.11B/G/N 17Mb/s
