3pin fan w/ 4 pin header on MOBO?
What happens if you have a fan with a 3pin connector and your mobo has a 4pin fan header? Does it work?
Also, what happens if the heatsink has an option for mounting another fan, and you only have 1 fan header on the mobo?
    eMachines ET 1161-05
    AMD Athlon 64 X2 6000+ 3.0 GHz AM2 Dual Core
    3gb
    Galaxy GeForce GT 430 - 1gb DDR3 - 128bit Memory Interface
    Realtek HD Audio
    Samsung 23" LED, 1920 x 1080 resolution
    1920x1080
    160gb Seagate
    Cool Master Extreme Power Plus - 500watts
    APEVIA X-Trooper Case w/ Side Window-Blue
    4, 120mm fans. 1, 200mm fan. Sunbeamtech Rheobus-Extreme
    Logitech k800 Wireless Illuminated Keyboard
    150mbps
    Linksys WUSB100 Insignia 2:1 Sound system.
Yes, the fan will work. It will not be able to alter its speed though, as the 4th pin is for the pulse-width modulation feature of suitable fans (the other 3 pins being +12V, Gnd, and rpm sensing).
You can either use a splitter cable and attach both to the same header, or you can use an adapter to connect the other fan to a spare molex connector.
    Dwarf Dwf/11/2012 r09/2013
    ASRock Z77 Extreme4-M
    ViewSonic VA1912w Widescreen
    Gigabyte IF233
Thank you for the reply.
Will the 3 pin fan run at full RPM since it doesn't have the pin for the pulse-width modulation feature?
Do all 4 pin fans have the PWM feature? I don't know if mine has that feature......
    3gb
    Realtek HD Audio
    1920x1080
    160gb Seagate
    150mbps
Yes, the 3 pin fan will run at full speed.
Generally speaking, most fans with 4 pins will have the PWM feature and, with the exception of certain manufacturers who use proprietary hardware (Dell, for example), these are interchangeable providing that they physically fit.
    Gigabyte IF233
Can you get a 3pin to 4 pin adapter?
    3gb
    Realtek HD Audio
    1920x1080
    160gb Seagate
    150mbps
there is sometimes a setting in the bios for (3-Pin) mode... Which is actually linear voltage control. If his particular mobo supports it.
    Amd Phenom II x4 965 BE rev.C2
    MSI ms-7599
    A-DATA DDR3-1600G PC3-12800 4GBx2
    Biostar NVIDIA GeForce 9400GT mn: VN9402THG1
    Creative SoundBlaster Audigy 2 Zs
    Compaq FS7550 (D-SUB)
    1600*1200
    Western Digital WD10 EADS-00L5B1 SATA (1TB) (Main drive) Hitachi HDS721010CLA332 SATA (1TB) (Secondary drive) Samsung HM250HI SATA (250GB) (Music and swap) Western Digital WD800BB-75CAA0 IDE 133 (80GB) (misc)
    RAIDMAX RX-850AE 850 Watt 12x4 rail 80plus gold PSU
    Cooler Master RC-430-KWN1 (elite 430)
    Corsair Hydro Series H50 (*120mm (x1))
    I Home Lazer
    Standard Microsoft (500)
    around 4 Mb a sec
    CD-rom's TSSTcorp CDDVDW SH-S223L SATA (Samsung) HL-DT-ST DVDRAM GH22NS40 SATA (LG)
