My Graphics Card Cooler (home made)
nostaw5
"POW" Ur dead
Power User
Just letting my friends (actually depends on if you like me) at Vistax64.com know about the home made cooler i made for my graphics card.
EDIT: pictures below.
Materials used: (will differ to other cards)
1X AMD Athlon II Cooler (Aluminium Heatsink, took off fan.)
2X 1/8" 4-40 threaded rods
4X M6 Nuts
4X M4 Washers (small base)
4X M4 (large base)
1X a saw that can cut through metal
Reasons why I am doing this: My HD 6450 1GB was overclocked higher than previously maxed with MSI afterburner and MAX temps in games were 64-72c
The stock Gigabyte cooler w/ fan is small.
Hopefully the NEW home made cooler will do better.
EDIT #2:
Results are pleasing:
I used MSI Kombustor and a 30min stress test to record temps
STOCK HEATSINK
PC idle: 52c
HOME MADE
PC idle: 49c (in picture)
STOCK HEATSINK
MSI Kombustor: 72c @ 851/1010
HOME MADE HEATSINK
MSI Kombustor: 57c @ 851/1010 (see picture below)
    Custom Gaming Rig 780G
    AMG Athlon II X2 255 3.8/2MB/2500MHz 45nm AM3
    Gigabyte GA-MA78LMT-S2 AM3, Core Boost, Ultra Durable 3
    2X 4GB Kingston DDR3 1066MHz @ 1666MHz Dual Channel
    HIS HD Radeon 7770 GHz Edition iCooler Core: 1000MHz
    Realtek HD Audio
    Dell E2311H DVI/VGA 5ms response, Full HD
    1920x1080 @ 60Hz
    320GB Seagate Barracuda 7200.02 SATA II
    Cooler Master Extreme Power Plus 700w
    Lian-Li PC-6010 With Side Window
    Aywun A4 80mm fan
    Logitech K120 Wired Mouse
    Logitech K120 Wired Keyboard
    802.11B/G/N 17Mb/s
    AMD Catalyst 12.6 Thomson A/B/G/N Router LiteON CD/DVD Player GAME PERFORMANCE: Battlefield 3: 41 FPS High 1x AA @ 1280x720 Mass Effect 2 and 3: 60 FPS Highest 4x AA @ 1920x1080 Counter Strike Source (and other Valve games): 300 FPS (max FPS in game) Highest settings 8x AA 16x AF @ 1920x1080!!!
Love to see that.
Just make sure all your memory chips are cooled too
    Dual L5639 // i7 950 @ 4.0Ghz
    gtx 560 ti // gtx 260-216
    Dual 22" // Headless
Love to see that.
Hey Patonb!!!
the memory chips were not covered by the stock heatsink BUT the fins of my new one do. i do not however, have any thermal pads.
XD
    Realtek HD Audio
    1920x1080 @ 60Hz
    Aywun A4 80mm fan
    802.11B/G/N 17Mb/s
Nice hack! Great results.
Indeed, although it could use a bit more touch up's like shave the rods down at the back of the cards, 1 rod hits my northbridge heatsink and might be moving heat onto-off both heatsinks :O
Some thermal pads on the memory
smooth the edges off the cut section of cooler :D
other than that it works well :D
    Realtek HD Audio
    1920x1080 @ 60Hz
    Aywun A4 80mm fan
    802.11B/G/N 17Mb/s
Ok here is an update:
Temps are GREAT!!! :D
Mass effect 2 is my most demanding game, Old temps hit 70-74c
Now with ALL my games (from light to demanding graphics)
ALL temps NEVER go over 60!!!
The reason was new thermal paste on my NEW homemade heatsink.
Happy Flyeting
    Realtek HD Audio
    1920x1080 @ 60Hz
    Aywun A4 80mm fan
    802.11B/G/N 17Mb/s
