I now have a home built AMD pc which came with a Foxconn AMD Certified CPU Cooler (AKA Stock cooler).
I overclock my Athlon II X2 255 from 3.1 to 3.8...
Now here is the problem. The temps sit at 45c with the Stock cooler but 36c with an Aywun A10 (or something) BUT HERE ARE THE PROBLEMS:
Stock cooler good side: quiet, small, mobo controlled fan.
Stock cooler Bad side: Hot, small, not much to look at.
AYWUN A-10 good side: Big to look at, keeps cpu cool
AYWUN A-10 bad side: Under load gets loud, big (maybe restricts airflow) have to use fan controller to keep quiet.
So my fellow overclockers which do you reccomend i use?
- Custom Gaming Rig 780G
- AMG Athlon II X2 255 3.8/2MB/2500MHz 45nm AM3
- Gigabyte GA-MA78LMT-S2 AM3, Core Boost, Ultra Durable 3
- 2X 4GB Kingston DDR3 1066MHz @ 1666MHz Dual Channel
- HIS HD Radeon 7770 GHz Edition iCooler Core: 1000MHz
- Realtek HD Audio
- Dell E2311H DVI/VGA 5ms response, Full HD
- 1920x1080 @ 60Hz
- 320GB Seagate Barracuda 7200.02 SATA II
- PSU
- Cooler Master Extreme Power Plus 700w
- Case
- Lian-Li PC-6010 With Side Window
- Cooling
- Aywun A4 80mm fan
- Logitech K120 Wired Mouse
- Logitech K120 Wired Keyboard
- 802.11B/G/N 17Mb/s
- Other Info
- AMD Catalyst 12.6 Thomson A/B/G/N Router LiteON CD/DVD Player GAME PERFORMANCE: Battlefield 3: 41 FPS High 1x AA @ 1280x720 Mass Effect 2 and 3: 60 FPS Highest 4x AA @ 1920x1080 Counter Strike Source (and other Valve games): 300 FPS (max FPS in game) Highest settings 8x AA 16x AF @ 1920x1080!!!
