You should upgrade or use an
alternative browser .
Control Fan speed with registry help
i have an HP pavalon DV9700 and it overheats quick
iv been following this but now i am stuck at editing the .aml
control fan speed with registry hack
i cant figure out where my fan speed value is
.asl file attached to help me find it.
Custom built Desktop
AMD Phenom II X6 1090T Black Edition 3.2Ghz
MSI 890FXA-GD70 AM3 AMD 890FX
8GB Adata Gaming series 2.0 DDR3 1600
MSI Twin Frozr 5830 X2 with MSI 5850 Crossfired
Asus 19", Acer 17"
1400x900
OCZ Agility 3 60gb, 500GB F3 Samsung Spin point and 5 other HDD's
850W OCZ
NZXT Phantom
2 200mm fans with 6 120mm fans
Logitec G9
Saitek 2
Major AMD, ATI and MSI Enthusiast.
٩(͡๏̯͡๏)۶
I don't think its possible, although I have no experience in overclocking, one of the comments on that tutorial is:
SpeedFan was made with desktops in mind. Notebooks control the fans differently compared to desktops. It will not work.
Is your laptop in a well ventilated place? Have you considered getting a cooling mat? Is the fan nice and clean? That last one is very important, my laptop was reaching 89 celsius before I removed the crap from the fan, now it reaches 58
Tom
Build #1
Intel Core i7 3770K @4.4GHz
ASUS P8Z77-V PRO
Integrated on motherboard
23" LG LCD/LED IPS
1920*1080
Samsung EVO 128GB SSD
Seagate Barracuda 2TB 7200rpm
NZXT Phantom 410
Dual L5639 // i7 950 @ 4.0Ghz
gtx 560 ti // gtx 260-216
Dual 22" // Headless
