You should upgrade or use an
alternative browser .
I have overclocked my 2.4Ghz Pentium Dual Core E2220 to 3 Ghz. I Used the stock CPU Cooling Fan. ( I upgraded my MOBO to a GA-G41M-COMBO and my GPU to a Asus EAH 5570 )
Acer Aspire M1641
Intel Dual Core E2220 2.4GHZ
2GB DDR2
ATI Sapphire Radeon HD 3450 256MB PCI-E 2.0
Philips 192E WideScreen LCD Monitor 18.5`
Seagate ST3250318AS, Western Digital WD3200AAJS-22L7A0
2048kbps downloading, 512kbps downloading
Planning to Upgrade my PC...
Hi AlOnan,
Is there a question or problem here? Are you looking for confirmation that this was acceptable? Are you just posting to let us know what you've done and that it worked? I'm not sure how to respond.
Also, since you are using Windows 7, you may want to consider posting from now on in our sister site
www.sevenforums.com which is dedicated to Windows 7 (as we are to Vista). They will probably be able to assist you better than we can as they specialize in your operating system.
Thanks and good luck!
1920 x 1200 pixels
Dell AIO Printer A940
6TO4 Adapter
Microsoft ISATAP Adapter
Router Linksys / WRT54G -01
No, I`m just posting to let you know that it worked. I had no overheating problems.
Acer Aspire M1641
2GB DDR2
Excellent! Well done! Thanks for letting us know it worked - it may help others who are considering the same thing.
I will request that this thread be marked as solved.
Good luck and best wishes!
1920 x 1200 pixels
6TO4 Adapter
