Overclocking MSI 5830 Twin Frozr help
I saw on the Guru3D they were able to overclock theirs to 928 my max is at 875. any idea what i can do? Also i have an AMD X6 hexa core 1095T and they also clocked it to 4.1 GHZ would it be safe with the stock heatsink?
    Custom built Desktop
    AMD Phenom II X6 1090T Black Edition 3.2Ghz
    MSI 890FXA-GD70 AM3 AMD 890FX
    8GB Adata Gaming series 2.0 DDR3 1600
    MSI Twin Frozr 5830 X2 with MSI 5850 Crossfired
    Asus 19", Acer 17"
    1400x900
    OCZ Agility 3 60gb, 500GB F3 Samsung Spin point and 5 other HDD's
    850W OCZ
    NZXT Phantom
    2 200mm fans with 6 120mm fans
    Logitec G9
    Saitek 2
    Major AMD, ATI and MSI Enthusiast.
Well, firstly NEVER EVER expect what you see others do.
1) You're only 50mhz off, thats pretty close that you really won't see any more gains, and thats just the variations in chips. Plus not knowing how they oc'd its impossible to give ideas.
2) No, overclocking on stock heatsinks will not cool your cpu enough to be safe. You can still overclock, but not that high.
    Dual L5639 // i7 950 @ 4.0Ghz
    gtx 560 ti // gtx 260-216
    Dual 22" // Headless
I have oc'd two of those and reached 4 gig easily both times so your good to go with the cpu but heed the advice ^^^^^^^^^^ dont even try on stock cooling
and if you have never overclocked before do plenty of research first :)
    XFX 780i
    4GB OCZ PC2-8500C5 DDR2
    Gainward GTX260/216 SLI
    Creative X-FI Xtreme Gamer
    Dell UltraSharp 2209WA 22"
    OCZ Modstream 700w
    Titan Fenir
    Logitech G5 Gamer
    Razer Reclusa
    8mb
