Okay, I know this problem plagues everyone, especially those more with a laptop due to the lack of airflow space. Previously I had believed that the cause was a game that I played called RuneScape. However, after I started getting all the necessary Windows Vista Updates done, I started to have the overheating problems again. Can updates cause overheating problems at all?
I had gone to factory defaults cause of a Nvidia Driver Problem (have not seen this problem at all once that was done and haven't updated to current driver cause of it). I never played RuneScape till yesterday in order to find out if the problem was something else and my computer had shutdown cause of the overheating problem. Here are my specs and values from CPUID Hardware Monitor (Min/Max) that I have:
Windows Vista Home Premium, Service Pack 1 (Know about the second one)
Manufacturer: Hewlett-Packard
Model: HP G60 Notebook PC
Processor: AMD Athlon Dual-Core QL-64 2.10 GHz x2
Memory (RAM): 3.00 GB
System type: 32-bit
CPUID Values: (Some of these I have no idea what they mean.) * No idea what it is.
ACPI*
- TZS0 Min: 49 °C Max: 60 °C
- TZS1 Min: 49 °C Max: 60 °C
AMD Athlon X2 QL-64
- Core #0 Min: 55 °C Max: 72 °C
- Core #1 Min: 55 °C Max: 71 °C
- Powers Min: 11.40 W Max: 30.80 W
NVIDIA GeForce 8200M G
- GPU Core Min: 59 °C Max: 69 °C
WDC WD3200BEVT-60ZCT1*
- Assembly Min: 34 °C Max: 41 °C
- Air Flow Min: 34 °C Max: 41 °C
Battery 1
- Voltages Min: 12.47 V Max: 12.47 V
- Designed Capacity Min: 47520 mWh Max: 47520 mWh
- Full Charge Capacity Min: 41483 mWh Max: 41483 mWh
- Current Capacity Min: 40295 mWh Max: 41483 mWh
- Wear Level Min: 12% Max: 12%
-Charge Level Min: 97% Max: 100%
I always keep my computer plugged in, so not sure if that has any impact. Also my battery plan is the HP Recommended for HP laptops and always use a cooling pad. If anyone needs any extra information to help me out just ask.
System type: 32-bit
ACPI*
AMD Athlon X2 QL-64
Battery 1
- Hewlett-Packard/G60-231WM
- AMD Athlon Dual-Core QL-64, 2.10 GHz, 2 Logical Processors
- Wistron 303C
- 3.00 GB
- NVIDIA GeForce 8200M G
- Conexant High Definition SmartAudio221/NVIDIA High Def Audio
- Generic PnP Monitor
- 1366 by 768 pixels
- WDC WD3200BEVT-60ZCT1 (320GB, SATA300, 2.5", 5400rpm, NCQ, 8MB Cache)
- Synaptics PS/2 Port TouchPad
- Standard 101/102-Key/Microsoft Natural PS/2 Keyboard HP QLB
- 54.0 Mbps
- Other Info
- Mouse: Logitech HID-compliant Cordless Mouse
