niemiro
Banned
Hello all!
Some of you may know me. Like my software and WinSxS (I love the way WinSxS all fits together!) but am utterly clueless about the hardware. Please forgive me this question!
I have a DESKTOP PC which is NOT overclocked in any way. It is reasonably powerful (see specs) and is a Dell. However, it is used to the extremes of its ability - regularly.
I would just like to ask you what the temperatures you would consider good, warm, and hot for both the GPU and CPU. I know the GPU can get quite hot, but I would please like to know how hot, so that I can learn.
I have a feeling that mine are quite hot. Most of the time I get:
CPU: 52 degrees Centigrade (C)
GPU: 128 C
These seem awfully hot. Putting my hand on the GPU plastic casing after use makes me think that these are not anomalous!
Thanks so much in advance!
Richard
EDIT: All of the fans have been confirmed as working, and it has good airflow all around, and always has had.
GPU: 128 C
Richard
- Dell XPS 420
- Intel Core 2 Quad Q9300 2.50GHz
- Stock Dell 0TP406
- 4 gb (DDR2 800) 400MHz
- ATI Radeon HD 3870 (512 MBytes)
- Onboard
- 1 x Dell 2007FP and 1 x (old) Sonic flat screen
- 1600 x 1200 and 1280 x 1204
- 1 x 640Gb (SATA 300) Western Digital: WDC WD6400AAKS-75A7B0 1 x 1Tb (SATA 600) Western Digital: Caviar Black, SATA 6GB/S, 64Mb cache, 8ms Western Digital: WDC WD1002FAEX-00Z3A0 ATA Device
- PSU
- Stock PSU - 375W
- Case
- Dell XPS 420
- Cooling
- Stock Fan
- Advent Optical ADE-WG01 (colour change light up)
- Dell Bluetooth
- 120 kb/s
- Other Info
- ASUS USB 3.0 5Gbps/SATA 6Gbps - PCI-Express Combo Controller Card (U3S6)
