Phenom X4 overclocking
Hello all, I was just curious if you all think it would be beneficial to overclock an AMD Phenom x4 rated at 1.8GHz. I have upgraded the power supply(bumped to 450W if I can remember correctly) and run a Nvidia 9500GT graphics card.
If this is worth the effort, where should I start my research on this procedure? I've always tried to avoid messing with the BIOS because I know little about it.
    AMD Phenom x4 1.8 GHz
    Nvidia 9500GT
    LG 22"
    1920x1080
Google how to overclock x4.
Theres many many sites with the answer, as this sites more about vista than hardware.
If you reAD and proced smartly, overclockings easy and safe.
    Dual L5639 // i7 950 @ 4.0Ghz
    gtx 560 ti // gtx 260-216
    Dual 22" // Headless
You are mostly going to bump the Front Side bus and bump the core voltage. just be careful with the voltage...... you can kill a chip quicker than heat will if you go to high.... That is another thing *Heat* Make shure you are useing a good cooler and mot some stock one.
    Amd Phenom II x4 965 BE rev.C2
    MSI ms-7599
    A-DATA DDR3-1600G PC3-12800 4GBx2
    Biostar NVIDIA GeForce 9400GT mn: VN9402THG1
    Creative SoundBlaster Audigy 2 Zs
    Compaq FS7550 (D-SUB)
    1600*1200
    Western Digital WD10 EADS-00L5B1 SATA (1TB) (Main drive) Hitachi HDS721010CLA332 SATA (1TB) (Secondary drive) Samsung HM250HI SATA (250GB) (Music and swap) Western Digital WD800BB-75CAA0 IDE 133 (80GB) (misc)
    RAIDMAX RX-850AE 850 Watt 12x4 rail 80plus gold PSU
    Cooler Master RC-430-KWN1 (elite 430)
    Corsair Hydro Series H50 (*120mm (x1))
    I Home Lazer
    Standard Microsoft (500)
    around 4 Mb a sec
    CD-rom's TSSTcorp CDDVDW SH-S223L SATA (Samsung) HL-DT-ST DVDRAM GH22NS40 SATA (LG)
