Need help OCing my laptop
hansenderek
Before you ask about it yea i kno tht laptops arent supposed to be OCed because they could burn up but my laptop has a really great fan in it and everything idled at about 50-70 even on full load with programs tht i downloaded to test them...and my intel cpu sits at 40-50 C at all times...idk y but thts kinda why i want to oc a little bit up to like -2.6-2.8
ok so yea i kno dont overclock laptop and yada yada...but ive got some stuff for my laptop to help it and on full cpu load the fan doesnt even hit the high fan setting and my processors idle at about 40-50 C and i figure that i can overclock at least a little bit...
system specs
Intel(R) Core(TM)2 duo CPU 2.40 GH NVIDIA geforce 9700 GT 6.00GB RAM Windows Vista Home Premium 64bit laptop
Nvidia 9600 gtm oc core clock: 500>610
shader clock: 1250>1525
memory clock:400>510
its a hp laptop so cant do the bios overclock...i need some software to do it..and im not worried about voltage because i have ramclock and if i need to i can add a little voltage to my system...i did undervolt it quite a bit...intel overvolts their processors wayyyy to much lol :P but yea... if you can help it would be really appreciated.
ive looked around alot and found nothing...i looked for my pll and all i found was what i thought was it but not sure at all it goes like this
IC: 1000m-512ANM?
the ? is because the last letter or number was covered up....its either H, 11, LL....not sure which one tho
Hey there. No thats not ur Pll chip. I know cuz ive overclocked a laptop to 2.6GHz with a crappy fan. Im not quite sure i can help for your model BUT... i can give you some tips. The Pll as people say is near the processor. Not entirely true... I found mine hiding in a corner and i needed a torch to find it. Next the name of the ones i know are ICS and RTM and Winbond. There are more but it should look like this
http://www.legitreviews.com/images/reviews/1158/EVGA-P55-FTW-SLI-PLL.jpg
Now depending on your chip you might need SETfsb, Clockgen. look on google. Once you found it on the software go slowly up. Once it has gone to the point your pc freezes dont worry. restart and put it to one or 2 slides just under.Test the stress of the heat using prime95. If its stable GREAT!!!
Now if like me you wanted to keep it overclocked when the laptop starts up download something called Setfsb Autotool. it doesn't load with windows but if you put it in the startup folder of windows. it loads as soon as you login. there are 3 shortcuts to put on your desktop. an on shortcut,off shortcut and a MANAGER shortcut. You need to enter your STOCK speed, MAX multiplyer and new overclocked setting. for this you need CPU-z. it will tell you your max. mine is 10. If you got it wrong and the pc freezes. restart in safe mode and delete auto on icon from startup. Then re-enter the config into manager GET IT RIGHT.
then your all sweet.
Hope this helps
    Custom Gaming Rig 780G
    AMG Athlon II X2 255 3.8/2MB/2500MHz 45nm AM3
    Gigabyte GA-MA78LMT-S2 AM3, Core Boost, Ultra Durable 3
    2X 4GB Kingston DDR3 1066MHz @ 1666MHz Dual Channel
    HIS HD Radeon 7770 GHz Edition iCooler Core: 1000MHz
    Realtek HD Audio
    Dell E2311H DVI/VGA 5ms response, Full HD
    1920x1080 @ 60Hz
    320GB Seagate Barracuda 7200.02 SATA II
    Cooler Master Extreme Power Plus 700w
    Lian-Li PC-6010 With Side Window
    Aywun A4 80mm fan
    Logitech K120 Wired Mouse
    Logitech K120 Wired Keyboard
    802.11B/G/N 17Mb/s
    AMD Catalyst 12.6 Thomson A/B/G/N Router LiteON CD/DVD Player GAME PERFORMANCE: Battlefield 3: 41 FPS High 1x AA @ 1280x720 Mass Effect 2 and 3: 60 FPS Highest 4x AA @ 1920x1080 Counter Strike Source (and other Valve games): 300 FPS (max FPS in game) Highest settings 8x AA 16x AF @ 1920x1080!!!
